[OpenLayers-Users] Problem with NASA Terra WMS-Service
HarryS mapcollect at gmx.net
Thu Nov 8 07:52:53 EST 2007
Thanks Dara - that works !
Harry
Dara Dowd wrote:
> You can do
>       var terra = new OpenLayers.Layer.WMS( "Terra Images",
>        "http://wms.jpl.nasa.gov/wms.cgi?",
>        {layers: 'daily_terra'} );
> terra.setTileSize(new OpenLayers.Size(512,512));
> Dara
> HarryS wrote:
>> That's fine ! But how would be the syntax to give tilesize option to a
>> single layer in this case ?:
>> Harry
>> Pierre GIRAUD wrote:
>>> The tileSize option you gave to your map object can be individually
>>> given to your layers.
>>> Regards,
>>> Pierre
>>> On Nov 6, 2007 2:39 PM, HarryS <mapcollect at gmx.net> wrote:
>>>> OK, I can add this line:
>>>>             map = new OpenLayers.Map('map', {tileSize: new
>>>> OpenLayers.Size(512, 512)});
>>>> Then it works for Terra-layer
>>>> But than I can't display my Kamap-Layers, which have 256x256 tilesize.
>>>> How can I tell OpenLayers to only use tilesize 512x512 for Terra-layer
>>>> Thanks !
>>>> Harry
>>>> HarryS wrote:
>>>> > I have a problem with this layer:
>>>> > It worked a while but meanwhile the JPL-Server returns an
>>>> Error-message:
>>>> > <?xml version='1.0' encoding="UTF-8" standalone="no" ?>
>>>> > <!DOCTYPE ServiceExceptionReport SYSTEM
>>>> > "http://onearth.jpl.nasa.gov/exception_1_1_1.dtd ">
>>>> > <ServiceExceptionReport version="1.1.0">
>>>> >   <ServiceException>
>>>> >     This tile size is not supported. For tiled access, see available
>>>> > layers, described at http://onearth.jpl.nasa.gov/tiled.html
>>>> >   </ServiceException>
>>>> > </ServiceExceptionReport>
>>>> > The problem is that OL wants 256x256 tiles but the JPL-server only
>>>> > provides 512x512 tiles. Can I adjust OL to load only 512x512 tiles ?
>>>> > Thanks,
>>>> > Harald
>>>> View this message in context:
>>>> http://www.nabble.com/Problem-with-NASA-Terra-WMS-Service-tf4757989.html#a13606766
>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
View this message in context: http://www.nabble.com/Problem-with-NASA-Terra-WMS-Service-tf4757989.html#a13646350
