[OpenLayers-Users] Problem with NASA Terra WMS-Service
Dara Dowd
dara.dowd at vertexsys.co.jp
Tue Nov 6 19:36:25 EST 2007
You can do
var terra = new OpenLayers.Layer.WMS( "Terra Images",
"http://wms.jpl.nasa.gov/wms.cgi?",
{layers: 'daily_terra'} );
terra.setTileSize(new OpenLayers.Size(512,512));
Dara
HarryS wrote:
> That's fine ! But how would be the syntax to give tilesize option to a
> single layer in this case ?:
> Harry
> Pierre GIRAUD wrote:
>> The tileSize option you gave to your map object can be individually
>> given to your layers.
>> Regards,
>> Pierre
>> On Nov 6, 2007 2:39 PM, HarryS <mapcollect at gmx.net> wrote:
>>> OK, I can add this line:
>>> map = new OpenLayers.Map('map', {tileSize: new
>>> OpenLayers.Size(512, 512)});
>>> Then it works for Terra-layer
>>> But than I can't display my Kamap-Layers, which have 256x256 tilesize.
>>> How can I tell OpenLayers to only use tilesize 512x512 for Terra-layer ?
>>> Thanks !
>>> Harry
>>> HarryS wrote:
>>> > I have a problem with this layer:
>>> > It worked a while but meanwhile the JPL-Server returns an
>>> Error-message:
>>> > <?xml version='1.0' encoding="UTF-8" standalone="no" ?>
>>> > <!DOCTYPE ServiceExceptionReport SYSTEM
>>> > "http://onearth.jpl.nasa.gov/exception_1_1_1.dtd ">
>>> > <ServiceExceptionReport version="1.1.0">
>>> > <ServiceException>
>>> > This tile size is not supported. For tiled access, see available
>>> > layers, described at http://onearth.jpl.nasa.gov/tiled.html
>>> > </ServiceException>
>>> > </ServiceExceptionReport>
>>> > The problem is that OL wants 256x256 tiles but the JPL-server only
>>> > provides 512x512 tiles. Can I adjust OL to load only 512x512 tiles ?
>>> > Thanks,
>>> > Harald
>>> View this message in context:
>>> http://www.nabble.com/Problem-with-NASA-Terra-WMS-Service-tf4757989.html#a13606766
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
View this message in context: http://www.nabble.com/Problem-with-NASA-Terra-WMS-Service-tf4757989.html#a13619115
