[OpenLayers-Users] Problem with NASA Terra WMS-Service
HarryS
mapcollect at gmx.net
Tue Nov 6 09:36:20 EST 2007
That's fine ! But how would be the syntax to give tilesize option to a single
layer in this case ?:
var terra = new OpenLayers.Layer.WMS( "Terra Images",
"http://wms.jpl.nasa.gov/wms.cgi?",
{layers: 'daily_terra'} );
Harry
Pierre GIRAUD wrote:
> The tileSize option you gave to your map object can be individually
> given to your layers.
> Regards,
> Pierre
> On Nov 6, 2007 2:39 PM, HarryS <mapcollect at gmx.net> wrote:
>> OK, I can add this line:
>> map = new OpenLayers.Map('map', {tileSize: new
>> OpenLayers.Size(512, 512)});
>> Then it works for Terra-layer
>> But than I can't display my Kamap-Layers, which have 256x256 tilesize.
>> How can I tell OpenLayers to only use tilesize 512x512 for Terra-layer ?
>> Thanks !
>> Harry
>> HarryS wrote:
>> > I have a problem with this layer:
>> > It worked a while but meanwhile the JPL-Server returns an
>> Error-message:
>> > <?xml version='1.0' encoding="UTF-8" standalone="no" ?>
>> > <!DOCTYPE ServiceExceptionReport SYSTEM
>> > "http://onearth.jpl.nasa.gov/exception_1_1_1.dtd ">
>> > <ServiceExceptionReport version="1.1.0">
>> > <ServiceException>
>> > This tile size is not supported. For tiled access, see available
>> > layers, described at http://onearth.jpl.nasa.gov/tiled.html
>> > </ServiceException>
>> > </ServiceExceptionReport>
>> > The problem is that OL wants 256x256 tiles but the JPL-server only
>> > provides 512x512 tiles. Can I adjust OL to load only 512x512 tiles ?
>> > Thanks,
>> > Harald
>> View this message in context:
>> http://www.nabble.com/Problem-with-NASA-Terra-WMS-Service-tf4757989.html#a13606766
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/Problem-with-NASA-Terra-WMS-Service-tf4757989.html#a13607837
