[OpenLayers-Users] Problem with NASA Terra WMS-Service
Pierre GIRAUD
bluecarto at gmail.com
Tue Nov 6 08:45:28 EST 2007
The tileSize option you gave to your map object can be individually
given to your layers.
Regards,
Pierre
On Nov 6, 2007 2:39 PM, HarryS <mapcollect at gmx.net> wrote:
> OK, I can add this line:
> map = new OpenLayers.Map('map', {tileSize: new
> OpenLayers.Size(512, 512)});
> Then it works for Terra-layer
> But than I can't display my Kamap-Layers, which have 256x256 tilesize.
> How can I tell OpenLayers to only use tilesize 512x512 for Terra-layer ?
> Thanks !
> Harry
> HarryS wrote:
> > I have a problem with this layer:
> > var terra = new OpenLayers.Layer.WMS( "Terra Images",
> > "http://wms.jpl.nasa.gov/wms.cgi?",
> > {layers: 'daily_terra'} );
> > It worked a while but meanwhile the JPL-Server returns an Error-message:
> > <?xml version='1.0' encoding="UTF-8" standalone="no" ?>
> > <!DOCTYPE ServiceExceptionReport SYSTEM
> > "http://onearth.jpl.nasa.gov/exception_1_1_1.dtd ">
> > <ServiceExceptionReport version="1.1.0">
> > <ServiceException>
> > This tile size is not supported. For tiled access, see available
> > layers, described at http://onearth.jpl.nasa.gov/tiled.html
> > </ServiceException>
> > </ServiceExceptionReport>
> > The problem is that OL wants 256x256 tiles but the JPL-server only
> > provides 512x512 tiles. Can I adjust OL to load only 512x512 tiles ?
> > Thanks,
> > Harald
> View this message in context: http://www.nabble.com/Problem-with-NASA-Terra-WMS-Service-tf4757989.html#a13606766
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
