[OpenLayers-Users] Extract/read attributes from GML
Arnd Wippermann arnd.wippermann at web.de
Wed Nov 14 12:35:36 EST 2007
propably you have problems with the namespaces. This is, what I get when I
load the gml with IE6:
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and
then click the Refresh button, or try again later.
Reference to undeclared namespace prefix: 'wfs'. Error processing resource
'http://www.nabble.com/file/p13750828/gml.xml'. ...
<wfs:FeatureCollection xsi:schemaLocation="http://www.fao.org/fi
http://193.43.36.238:8282/geoserver/wfs/DescribeFeatureT...
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von springrider
Gesendet: Mittwoch, 14. November 2007 17:44
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Extract/read attributes from GML
Thanks for your answer
I think i was not clear, I used to be a XML/XSL developper so i wanted to
access this specific tag. After browsing the different examples and mainly
the GMLparser example, i found some answers. I can obtain using OL code the
bouding box of my polygon directly.
This is a my current code:
g =  new OpenLayers.Format.GML();
features = g.read(req.responseText);
var bounds = features[1].geometry.getBounds();
It works fine with the XMLs available for this OL example but with my GML, i
always have features.length=0. By doing Alert(req.responseText), i obtain
effectively my GML but no features are considered in it. In attachment, you
will find my GML: http://www.nabble.com/file/p13750828/gml.xml gml.xml .
I really hope you can help me.
Thanks
Sylvain
Christopher Schmidt-4 wrote:
> On Wed, Nov 14, 2007 at 07:17:08AM -0800, springrider wrote:
>> Good morning
>> I would be interested to extract/read text within some tags
>> (wfs:FeatureCollection\gml:boundedBy\gml:Box\gml:coordinates) from my
>> GML. I am now struggling trying to write the correct syntax. I tried
>> something like
>> that:
>>  var myGml= new
>> OpenLayers.Layer.GML("myGML","http://193.43.36.238:8282/geoserver/wfs
>> ?request=GetFeature&typename=fifao:Fao_areas&cql_filter=F_AREA=27");
>> var myExtent=
>> myGml.read("wfs:FeatureCollection\gml:boundedBy\gml:Box\gml:coordinat
>> es")
>> But it is not correct.Could you please help me? I would then use this
>> text to define the extent of my map.
> This isn't going to do what you want it to do.
> 1. None of the OpenLayers libraries include support for xpath like
> navigation of XML documents.
> 2. The GML parser returns features; additional metadata from the
> document is ignored.
> 3. The Layer is just about displaying data; you're more likely to want
> to use the Format (but it still won't do what you want.)
> You'll probably want to use the Format.XML class to load the data, and
> use standard DOM methods to manipulate the loaded XML, or the
> Format.XML specific getElementsByTagNameNS and the like.
> OpenLayers is a map library, rather than a geodata management
> framework, so it doesn't provide the tools to do what you want easily,
> as far as I'm aware.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context:
http://www.nabble.com/Extract-read-attributes-from-GML-tf4805707.html#a13750
828
Users mailing list
