[OpenLayers-Users] Adding a Mapserv Layer
Matthew Pulis
mpulis at gmail.com
Sun Nov 18 18:00:37 EST 2007
Just would like to update this thread.
Thanks to Arnd Wipperman, have fixed alot of the bugs I had, the only
bug (/problem) left is that the map is being cropped out, thus, when
you start moving the map, when it goes out from the borders, there is
just white blank canvas, instead of the map.
This is the code : http://pastebin.com/fce43cfb
(As one can see I already started to read through and use the source
of Chris Schmidt found here : http://boston.freemap.in/routing.html
for the routing I am planning)
Any help on this matter is extremely appreciated. You can see the bug
acting here : http://yancho.no-ip.org/~yancho/openl.html
Thanks and regards
Matthew
