[OpenLayers-Users] Adding a Mapserv Layer
Arnd Wippermann
arnd.wippermann at web.de
Mon Nov 19 12:48:14 EST 2007
You have to change your maxextent. Only tiles within the maxextent are
requested.
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Matthew Pulis
Gesendet: Montag, 19. November 2007 00:01
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Adding a Mapserv Layer
Just would like to update this thread.
Thanks to Arnd Wipperman, have fixed alot of the bugs I had, the only bug
(/problem) left is that the map is being cropped out, thus, when you start
moving the map, when it goes out from the borders, there is just white blank
canvas, instead of the map.
This is the code : http://pastebin.com/fce43cfb
(As one can see I already started to read through and use the source of
Chris Schmidt found here : http://boston.freemap.in/routing.html
for the routing I am planning)
Any help on this matter is extremely appreciated. You can see the bug acting
here : http://yancho.no-ip.org/~yancho/openl.html
Thanks and regards
Matthew
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
