[OpenLayers-Users] Custom control isn't working properly - how
to unregister?
Eric Lemoine
eric.c2c at gmail.com
Tue Nov 20 09:22:53 EST 2007
On Nov 16, 2007 4:14 PM, Pascal Ehlert <dadark at dadark.de> wrote:
> Hi mailing list!
> I'm trying to build my own control to enable the user to query some
> information depending on where he clicked.
> Now I'd like to add this control to my panel and change between
> normal navigation and query mode.
> Unfortunately there are two problems with it:
> The first is that the class for the control element in my panel
> doesn't change to olControlODAQueryItemActive when I click it,
To get OpenLayers to use the classes olControlODAQueryItemActive and
olControlODAQueryItemInactive for your control you need to place it in
an OpenLayers panel. See
<http://www.openlayers.org/dev/examples/panel.html> for an example on
how to use a panel.
You'd also need to declare your control using something like that:
OpenLayers.Control.ODAQuery = OpenLayers.Class(OpenLayers.Control, {
initialize: function(options) {
OpenLayers.Control.prototype.initialize.apply(this, [options]);
CLASS_NAME: "OpenLayers.Control.ODAQuery"
OpenLayers will derive class names (olControlODAQueryItemActive and
olControlODAQueryItemInactive) from your control's CLASS_NAME
property. This occurs in the Control.Panel code (see
<http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Control/Panel.js>).
> although the
> event is registered.
> The second is that I don't really know how to unregister it so that
> normal navigation is possible again.
Your class should override the unactivate() method and call
this.map.unregister() from this method.
> Oh, okay, there's just another problem that came to my mind:
> I'd also like it to unregister all default mouse handlers upon
> activation, so that you can't navigate in query mode.
Hmm, if you register a callback for the click event only, you should
still be able to navigate. Go back to us with examples if that doesn't
work.
Eric
