[OpenLayers-Users] Custom control isn't working properly - how
to unregister?
Pascal Ehlert
dadark at dadark.de
Wed Nov 21 08:55:18 EST 2007
Hi Eric!
First of all, thank you for your answer, I haven't expected it anymore.
> You'd also need to declare your control using something like that:
> OpenLayers.Control.ODAQuery = OpenLayers.Class(OpenLayers.Control, {
> initialize: function(options) {
> OpenLayers.Control.prototype.initialize.apply(this,
> [options]);
> CLASS_NAME: "OpenLayers.Control.ODAQuery"
Okay, I've done that and it looks much cleaner!
Unfortunately it is still no applying the ItemsActive appendix to the
css class name, but I
fixed it by setting this.active manually in both, my activate and
deactivate methods.
> Your class should override the unactivate() method and call
> this.map.unregister() from this method.
Sorry, but this is not working either, it complains that
this.map.unregister() does not return an object.
> Hmm, if you register a callback for the click event only, you should
> still be able to navigate. Go back to us with examples if that doesn't
> work.
That's right, but I want my users _not_ to be able to navigate
anymore when my own control is active.
I hope someone can help me with sorting out the last problems as well.
Regards
Pascal Ehlert
