[OpenLayers-Users] wheel zooming: want to turn off re-centre of
map at mouse location
Michael Quentel
mquentel at rim.com
Tue Nov 27 22:39:40 EST 2007
Solution...
In MouseDefaults.js, change the behaviour of defaultWheelUp and
defaultWheelDown so that they behave like the incremental zoom clicks on
the zoombar. Comment out the old (original) behaviour, and replace it
with map.zoomIn and map.zoomOut, like this:
/** User spun scroll wheel up
defaultWheelUp: function(evt) {
//if (this.map.getZoom() <= this.map.getNumZoomLevels()) {
// this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),
// this.map.getZoom() + 1);
this.map.zoomIn();
/** User spun scroll wheel down
defaultWheelDown: function(evt) {
//if (this.map.getZoom() > 0) {
// this.map.getZoom() - 1);
this.map.zoomOut();
Regards,
Mike Quentel
-----Original Message-----
Sent: Tuesday, 23 October 2007 11:42
To: users at openlayers.org
Subject: wheel zooming: want to turn off re-centre of map at mouse
location
In Navigation.js, it appears that the wheelChange function gets the
event x y, and not only zooms in or out, but also appears to re-centre
on the mouse event location. Is this correct? Please, need advice: I'd
like to turn off the map re-centreing on the mouse location when doing
mouse wheel zoom. Not having success changing this. Is Navigation.js
even where I should be trying to change this functionality?
wheelChange function as it is now:
wheelChange: function(evt, deltaZ) {
var newZoom = this.map.getZoom() + deltaZ;
if (!this.map.isValidZoomLevel(newZoom)) return;
var size = this.map.getSize();
var deltaX = size.w/2 - evt.xy.x;
var deltaY = evt.xy.y - size.h/2;
var newRes = this.map.baseLayer.resolutions[newZoom];
var zoomPoint = this.map.getLonLatFromPixel(evt.xy);
var newCenter = new OpenLayers.LonLat(
zoomPoint.lon + deltaX * newRes,
zoomPoint.lat + deltaY * newRes );
this.map.setCenter( newCenter, newZoom );
I tried to change the above to read the following:
//var size = this.map.getSize();
//var deltaX = size.w/2 - evt.xy.x;
//var deltaY = evt.xy.y - size.h/2;
//var zoomPoint = this.map.getLonLatFromPixel(evt.xy);
var zoomPoint = this.map.getCenter();
//var newCenter = new OpenLayers.LonLat(
// zoomPoint.lon + deltaX * newRes,
// zoomPoint.lat + deltaY * newRes );
var newCenter = zoomPoint;
That failed. I also tried the following, which also failed:
var deltaX = 1;
var deltaY = 1;
//debug
console.info("zoomPoint.lat: ", zoomPoint.lat);
console.info("zoomPoint.lon: ", zoomPoint.lon);
The Firebug console.info calls did not even appear. I'm not getting the
result I expected. What would work?
Thank you.
Cheers,
Mike Quentel
This transmission (including any attachments) may contain confidential information, privileged material (including material protected by the solicitor-client or other applicable privileges), or constitute non-public information. Any use of this information by anyone other than the intended recipient is prohibited. If you have received this transmission in error, please immediately reply to the sender and delete this information from your system. Use, dissemination, distribution, or reproduction of this transmission by unintended recipients is not authorized and may be unlawful.
