[OpenLayers-Users] Toolbar alternatives
Tim Schaub tschaub at openplans.org
Wed Nov 28 12:36:28 EST 2007
Hey-
Steve Lime wrote:
> Greetings: Has anyone developed alternatives to the basic toolbar controls that are part
> of OpenLayers? I'm interested in 2 or 3 state tools, being able to enable/disable tools, context
> sensitive help (e.g. "use this to ..."), being able to easily swap icon sets. Stuff like that.
> Or can the Panel class be used to do all that? I didn't see a basic button/tool control that would
> be added to a panel in the docs so I wasn't sure.
I think you got this answer already - but I wanted to add that I agree
that you should push the Control.Panel to do what you want.
If you store a reference to a control, you can always call
activate/deactivate on it.
If that control is part of a panel, call panel.activateControl(control).
  If that control is TYPE_BUTTON, it's trigger method will be called.
If that control is TYPE_TOGGLE, it will be switched active/inactive
depending on its current state.
Otherwise (TYPE_TOOL), the control will be activated and all other tool
type controls on the panel will be deactivated (one TYPE_TOOL control
active per panel).
The idea was that the panel class could be used to nest panels, giving
you menus or nested toolbars/panels.
You get your third state (hover) and icons from CSS.  This is not
perfect (in IE) and somewhat "hard" - largely due to poor docs.  But, I
think all that you want can be done.
There is certainly room for improvement in the panel class -
Chris/Schuyler wrote it in about 20 minutes as we sat around Chris'
dinner table at about 3am one morning - but the idea is sound.
In particular, you might find it handy to have accessor methods for the
controls in a panel (get controls by type, by name, by state, etc.).
I'd like to do this in a more generic way (see the patch for ticket 1153
if you're interested).  Just as it would be handy to be able to get
collections (of layers or controls) on a map based on arbitrary
criteria, the same would be nice on a panel (or a vector layer - with
features for example).  When that ticket makes it through the review
queue, if the idea has any traction, I'll apply the same to the control
panel (and a few other places).
Anyway, if you find shortcomings in the panel class (bugs or otherwise),
create tickets - I'd like to see it made more useful and I'm happy to
write patches.
Tim
> Thanks- Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> !DSPAM:4033,474c8b11270181431913854!
