[OpenLayers-Users] Adding new zoombar control?
samd
sdoyle_2 at yahoo.com
Thu Nov 29 14:22:02 EST 2007
Hey Chris,
So prior to adding the new controls we would construct the map and call
setCenter with a specific set of coords. and zoom level and it worked fine.
I just tried explicitly setting the map.zoom prior to adding the controls
and it showed a map although zoomed out extensively. I guess I just need to
add the extents or another parameter prior to adding the controls.
S.D.
Christopher Schmidt-4 wrote:
> On Wed, Nov 28, 2007 at 07:25:09PM -0800, samd wrote:
>> The last link you gave me shows a whole bunch of pink tiles on the botom.
> That's a result of a misconfigured TileCache. Is this the behavior you
> were seeing? This has nothing to do with the number of zoom levels.
> Share a code example that causes it to happen, and others may be able to
> help you.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Adding-new-zoombar-control--tf4891748.html#a14032979
