[OpenLayers-Users] Adding new zoombar control?
samd
sdoyle_2 at yahoo.com
Thu Nov 29 14:25:21 EST 2007
Hey Chris,
So prior to adding the new controls we would construct the map and call
setCenter with a specific set of coords. and zoom level and it worked fine.
I just tried explicitly setting the map.zoom prior to adding the controls
and it showed a map although zoomed out extensively. I guess I just need to
add the extents or another parameter prior to adding the controls.
S.D.
Christopher Schmidt-4 wrote:
> On Wed, Nov 28, 2007 at 06:37:44PM -0800, samd wrote:
>> Hello Chris,
>> It looks as if when you try to set the numZoomLevels on the map to
>> anything
>> other then 12 it results in pink tiles being generated.
> Not enough information. http://openlayers.org/dev/examples/lite.html has
> a numZoomLevels of 16,
> http://openaerialmap.hypercube.telascience.org/map/ has one of 25,
> neither results in pink tiles in the main part of the map.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Adding-new-zoombar-control--tf4891748.html#a14033040
