[OpenLayers-Users] bounds has no properties
David J. Renz
David.Renz at cityofmedford.org
Wed Jan 9 18:00:08 EST 2008
hello.
i am trying to get some input on this error.
i am new to OpenLayers and am just trying to load some of our own data.
i am trying to load a wms layer from geoserver (spatial data comes from
PostGres).
when i go to geoserver (administrator on my local machine) and look at
the demo requests for the service i am trying to load i can connect to
it fine, using either a standard wms request or an openLayers request.
however, when i try to load the wms layer in OpenLayers it fails.
Error: "bounds has no properties"
OpenLayers.js : line 533
I got the extents from ogrinfo. They seem to work for the geoserver
requests, but not the openLayers.
i am using the "Link to the hosted version" file from the website.
i cannot figure out where this is failing.
any leads would be appreciated.
ie (these work from geoserver):
geoserver demo: openLayers WMS
http://127.0.0.1:8080/geoserver/wms?bbox=4154738.29412617,104907.9070201
7272,4463982.597581711,516373.2919801983&styles=&Format=application/open
layers&request=GetMap&layers=MED_POST:cadstreets&width=550&height=250&sr
s=EPSG:2270
geoserver demo: wms
7272,4463982.597581711,516373.2919801983&styles=&Format=image/png&reques
t=GetMap&layers=MED_POST:cadstreets&height=600&width=600&srs=EPSG:2270
open layers code is below (fails):
var bounds = new
OpenLayers.Bounds(4154738.29412617,104907.90702017272,4463982.597581711,
516373.2919801983);
alert("Bounds are \n" + bounds);
var map = new OpenLayers.Map('map', { projection: "EPSG:2270",
units: "ft", maxExtent: bounds,});
var gs_wms = new OpenLayers.Layer.WMS( "Med",
"http://127.0.0.1:8080/geoserver/wms",{layers: 'MED_POST:cadstreets' ,
'transparent':"true",'format': "image/png"});
gs_wms.setVisibility(true);
map.addLayers(gs_wms])
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.addControl(new OpenLayers.Control.MousePosition());
map.zoomToMaxExtent();
Thanks,
david
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
