[OpenLayers-Users] Google layer not centering well + minor things
Cranio cranio at quipo.it
Tue Jan 15 04:20:38 EST 2008
Ok, don't now if you are interested, but I've found a fix.
As I see, when the map creation is done through a call in the BODY onload
event,
everything goes fine. I've managed to fix this in Joomla by setting this
kind of
onload event:
<BODY onload="_init();">
The _init() function tests the existence of the map creation function
and if present in the page, calls it:
function _init()
  if( typeof window.mapinit == "function" ) window.mapinit();
Cranio wrote:
> Well. I solved a minor problem by uploading the "theme" folder, which was
> missing.
> Now the Google logo and coords are displayed correctly.
> Though, the Google map still has this strange behaviour...
> Cranio wrote:
>> So I've managed to superimpose a Google layer with my WMS mapserver
>> layers.
>> I have now a strange behaviour though. While in Firefox everything goes
>> ok,
>> in IExplorer the WMS map center well, but Google maps don't align.
>> They seem shifted on the upper left corner, showing a gray border on the
>> right and bottom side, until I click on the map or zoom: after one
>> operation,
>> they align well. Same thing happens when I change Google layer, f.ex.
>> from
>> Satellite to Hybrid: on the change, the map loses its alignment to gain
>> it
>> again when I do whatever operation on the map.
>> Maybe there is a CSS align problem or what? I emphasize that my code is
>> embedded this way in a CMS (Joomla, as static content):
>> (note, there's no init() function on BODY onLoad event, the script is
>> directly executed)
>> ... JOOMLA CODE ...
>> [cut]
>> ... REST OF JOOMLA CODE ...
>> Another 2 questions:
>> - I figured out mapExtent by trial and error, but which is the projection
>> the coords refer to? They seem to be wrong.
>> - Why are coords and the google logo on the upper left corner?
View this message in context: http://www.nabble.com/Google-layer-not-centering-well-%2B-minor-things-tp14803541p14834959.html
