[OpenLayers-Users] Pink Tile Killing Me
Andrew de klerk andrew.deklerk at gmail.com
Wed Jan 16 03:30:05 EST 2008
To add to what Chris said. If you right click on the image and choose
properties and then copy the url and paste it into a new browser window -
what happens - do you get an error returned or an image?. That will allow
you to test it outside openlayers and determine if it is a mapserver
problem.
Andrew
Christopher Schmidt-4 wrote:
> On Mon, Jan 14, 2008 at 04:31:36PM -0500, Lee Keel wrote:
>> Well it turns out that I can not even use this as a smoke-and-mirrors
>> work around because i have some layers that won't display at all.  Not
>> even in ff.  When I use the URL from firebug, I am still getting the "The
>> specified CGI application misbehaved by not returning a complete set of
>> HTTP headers." error.  I currently have OpenLayers.IMAGE_RELOAD_ATTEMPTS
>> = 5.  I have set it to as high as 20.  Any ideas.  I am really behind the
>> 8 ball here.
> I would like to point out that the IMAGE_RELOAD_ATTEMPTS will *only*
> help if your failures are *transient* -- they will not help if the
> server never returns a tile. If you have a pink tile, and you right
> click to view it, and is still an error message, then reload_attempts
> won't help you: the problem is that your server is returning an error.
> It seems here like you're running into a mapserver crash. Check your
> apache logs for any errors reported there, possibly turn up mapserver
> debug to see if you can get some output, etc. In other words: debug your
> server, and figure out why the URL seems to be reproducibly not
> returning an image.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Pink-Tile-Killing-Me-tp14779152p14873822.html
