[OpenLayers-Users] changing attributes of elements in vector
layer and IE issues
Andreas Hocevar
andreas.hocevar at gmail.com
Wed Jan 16 11:02:55 EST 2008
O. Baum wrote:
> Hi again,
> 2008/1/16, Andreas Hocevar <andreas.hocevar at gmail.com>:
>> Then I suspect some style setting that VML does not like. This can
>> happen with some well-known color names that work in HTML, but not in
>> VML.
> I haven't used anything special... see below for details!
> I just used strokeColor, strokeOpacity and strokeWidth.
>> Can you post the snippet of your style hash that makes IE fail?
> I will send you the complete code of a test page which demonstrates the problem.
> The projection stuff is commented out because it is not supported in v2.5.
> Changing the script src from "/OpenLayers-2.5" to "/OpenLayers-trunk"
> makes my IE6 draw nothing at all.
> However, with v2.5 at first the mentioned non-desired polygon is drawn
> which switches to a polyline when clicking the button below the map.
> here we go:
> -----------8<---------------------------------------------------------------------------------
> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
> <html xmlns="http://www.w3.org/1999/xhtml"
> xmlns:v="urn:schemas-microsoft-com:vml">
> <head>
> <meta http-equiv="content-type" content="text/html; charset=UTF-8" />
> <title>OpenLayers Test4</title>
> <style type="text/css">
> #map {
> width: 100%;
> height: 512px;
> border: 1px solid black;
> background-color: red;
> </style>
> <!-- Localhost key -->
> <script src='http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhT2yXp_ZAY8_ufC3CFXhHIE1NvwkxTS6gjckBmeABOGXIUiOiZObZESPg'
> type="text/javascript"></script>
> <script src="/OpenLayers-2.5/OpenLayers.js" type="text/javascript"></script>
> <script type="text/javascript">
> var map, vectors;
> function init(){
> var options = {
> projection: new OpenLayers.Projection( "EPSG:900913" ),
> displayProjection: new OpenLayers.Projection( "EPSG:4326" ),
> units: "m",
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
> 20037508.34, 20037508.34),
> numZoomLevels: 18,
> controls: [
> new OpenLayers.Control.MouseDefaults(),
> new OpenLayers.Control.MousePosition(),
> new OpenLayers.Control.PanZoomBar()
> map = new OpenLayers.Map( 'map' , options );
> var hybrid = new OpenLayers.Layer.Google( "Google Hybrid Map",
> { type: G_HYBRID_MAP,
> 'maxZoomLevel':18 //,
> //'sphericalMercator': true
> map.addLayers( [hybrid] );
> // create and add the vector layer
> vectors = new OpenLayers.Layer.Vector( "Vector Layer" );
> map.addLayer( vectors );
> // define points for a polyline
> var pointList = [
> new OpenLayers.Geometry.Point( 13.38134765625,
> 52.50953477032727 ), // Berlin
> new OpenLayers.Geometry.Point( 2.35107421875,
> 48.850258199721495 ), // Paris
> new OpenLayers.Geometry.Point( 12.54639, 41.83683 ) // Rome
> // create a style for the polyline
> var normalStyle = OpenLayers.Util.extend( {},
> OpenLayers.Feature.Vector.style["default"] );
> normalStyle.strokeColor = "#00B000";
> normalStyle.strokeOpacity = .7;
> normalStyle.strokeWidth = 8;
> // create a feature from the point list
> var lineFeature = new OpenLayers.Feature.Vector( new
> OpenLayers.Geometry.LineString(pointList), null, normalStyle );
> // this method has to be called for every feature that
> will be added to the layer!!
> //lineFeature.geometry.transform( new
> OpenLayers.Projection("EPSG:4326"), new
> OpenLayers.Projection("EPSG:900913") );
> vectors.addFeatures( [lineFeature] );
> // zoom to the extent of the polyline
> map.zoomToExtent( lineFeature.geometry.getBounds() );
> </script>
> </head>
> <body onload="init()">
> <h1>OpenLayers With Google Layer Example</h1>
> <div id="map"></div>
> <div id="buttons"><input type="button" onclick="vectors.redraw();"
> value="redraw" /></div>
> </body>
> </html>
> ----------->8---------------------------------------------------------------------------------
> Thanks for your help!
> Regards,
> O. Baum
