[OpenLayers-Users] GetFeatureInfo problems
Maria Panagou
snowdrop at ath.forthnet.gr
Sun Jan 20 13:53:08 EST 2008
i'm trying to include a GetFeatureInfo query in my Openlayers app. In my html
I have included the following code for onclick event :
map.events.register('click', map, function (e) {
OpenLayers.Util.getElement('nodeList').innerHTML = "Loading...
please wait...";
var url = quakes.getFullRequestString({
REQUEST: "GetFeatureInfo",
EXCEPTIONS: "application/vnd.ogc.se_xml",
BBOX: quakes.map.getExtent().toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'text/html',
QUERY_LAYERS: 'Quakes',
layers:'Quakes',
WIDTH: map.size.w,
HEIGHT: map.size.h});
OpenLayers.loadURL(url, '', this, setHTML,setHTML);
OpenLayers.Event.stop(e);
function setHTML(response) {
response.responseText;
upon clicking on my point layer "Quakes" which is to be queried, i get no
results, just the loading..please wait text and I get the following error in
firebug
[Exception... "'Permission denied to call method XMLHttpRequest.open' when
calling method: [nsIDOMEventListener::handleEvent]" nsresult: "0x8057001e
(NS_ERROR_XPC_JS_THREW_STRING)" location: "<unknown>" data: no]
I've read about that it could be a proxy host problem but I don't think that
that is my case since the layer to query is at the same server as my mapfile
and PostGIS database. However I tried to setup a proxy host on the server,
which seems to work fine, but it doesn't correct the error message. Do i
really need a proxy host?
Next step, I tried to query the server localy issuing the following
GetFeatureInfo request :
http://127.0.0.1/cgi-bin/mapserv.exe?map=../htdocs/mpanagou/Quakes1.map&LAYERS=Quakes&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&QUERY_LAYERS=Quakes&STYLES=&EXCEPTIONS=application/vnd.ogc.se_xml&X=185&Y=194&FORMAT=image/png&SRS=EPSG:4326&INFO_FORMAT=text/html&WIDTH=650&HEIGHT=530&BBOX=19.2,34.5,29.8,42.1
it doesn't work however i think due to a different reason. When using
INFO_FORMAT=text/html, i am prompted to open/save a file containing:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
</ServiceException>
</ServiceExceptionReport>
when using INFO_FORMAT=text/plain i get the message
The XML page cannot be displayed
Cannot view XML input using style sheet. Please correct the error and then
click the Refresh button, or try again later.
Invalid at the top level of the document. Error processing resource
'http://127.0.0.1/cgi-bin/mapserv.exe?map=../htdocs/mpa...
GetFeatureInfo results:
and when INFO_FORMAT=application/vnd.ogc.gml I am prompted to open/save a
file whose contents are:
<?xml version="1.0" encoding="ISO-8859-1"?>
<msGMLOutput
xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Quakes_layer>
Does the template which i have defined in my mapfile has anything to do with
text/plain or application/vnd.ogc.gml INFO_FORMAT or only with text/html
format?
In the error log of Mapserver,in the lase case, I can see the following
information, that indicates that a record is being found but for a reason
that i don't understand not finally shown.
msPOSTGISLayerInitItemInfo called\r
msPOSTGISLayerGetShape called for record = 721\r
msPOSTGISLayerRetrievePK(): Found schema public, table quake_small.\r
msPOSTGISLayerRetrievePGVersion(): query = select substring(version() from
12 for (position('on' in version()) - 13))\r
msPOSTGISLayerRetrievePGVersion: Version String: 8.2.4\r
msPOSTGISLayerRetrievePGVersion(): Found version 8, 2, 4\r
msPOSTGISLayerRetrievePK: query = select attname from pg_attribute,
pg_constraint, pg_class, pg_namespace where pg_constraint.conrelid =
pg_class.oid and pg_class.oid = pg_attribute.attrelid and
pg_constraint.contype = 'p' and pg_constraint.conkey[1] =
pg_attribute.attnum and pg_class.relname = 'quake_small' and
pg_class.relnamespace = pg_namespace.oid and pg_namespace.nspname = 'public'
and pg_constraint.conkey[2] is null\r
msPOSTGISLayerParseData: unique column = codee, srid='', geom_column_name =
pos, table_name=public.quake_small\r
msPOSTGISLayerGetShape: DECLARE mycursor2 BINARY CURSOR FOR SELECT
"mag"::text,"depth"::text,asbinary(force_collection(force_2d(pos)),'NDR')
from public.quake_small WHERE codee = 721 \r
msPOSTGISLayerClose datastatement: pos FROM public.quake_small\r
msPOSTGISLayerClose -- query_result is NULL\r
msConnPoolRelease(Quakes,user=postgres password=manolis dbname=macroseismic
host=localhost port=5432,01BBD680)\r
Error in my_thread_global_end(): 1 threads didn't exit\r
I have defined a query results template in my mapfile which is the
following:
<!-- query template -->
<html>
<head>
<title>MapServer - ItemQuery</title>
</head>
<body bgcolor="#ffffff">
Codee: [codee]<br>
</body>
</html>
I kept it as simple as possible with only one attribute codee showing. Do i
need a header and footer template too?
The important parts of my mapfile are:
WEB
IMAGEPATH "C:/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
LOG "C:/temp/MapServer.log"
METADATA
WMS_TITLE "QuakeMap"
TITLE="QuakeMap"
WMS_ONLINERESOURCE="http://gaia.dbnet.ece.ntua.gr/cgi-bin/mapserv.exe?map=../htdocs/mpanagou/Quakes1.map&"
wms_feature_info_mime_type "text/html"
wms_srs "EPSG:4326"
END
END
LAYER
METADATA
WMS_TITLE="Quakes"
wms_include_items "all"
wms_srs "EPSG:4326"
wms_extent "19.2 34.5 29.8 42.1"
END
DUMP TRUE
TEMPLATE "Query Template results.html"
I'm totally confused here. I would appreciate some help. I read a lot of
documentation and forum threads but i can't figure out the problem.
View this message in context: http://www.nabble.com/GetFeatureInfo-problems-tp14985142p14985142.html
