[OpenLayers-Users] Problem wth ScaleBar
Tim Schaub
tschaub at openplans.org
Sat Jan 26 01:28:16 EST 2008
Hey-
David R Robison wrote:
> I was using the one in the tschaub sandbox. David
If you take a look at the patch for the scale bar, you'll see there are
some changes required to the default stylesheet.
http://trac.openlayers.org/attachment/ticket/24/scalebar.patch
In addition, you'll want to add your stylesheet with a link tag instead
of relying on the default dynamically added stylesheet.
<link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
Thanks for trying it out. Write back if you still have any trouble with it.
Tim
> Christopher Schmidt wrote:
>> On Mon, Jan 21, 2008 at 06:43:27PM -0500, David R Robison wrote:
>>> I am trying to get the OpenLayers.Control.ScaleBar working. I've added
>>> it to my map according to the example html. However, when my map draws,
>>> I get the units (in my case 'miles') but it displays at the bottom of
>>> the map and I get no scale bar. Its as if the scale bar is below the map
>>> and hidden. Any thoughts on how to get this to work correctly? Thanks, David
>> Are you adding ScaleBar (which isn't in trunk) or Scale()? OpenLayers
>> does not currently have a ScaleBar control.
>> Regards,
> David R Robison
> Open Roads Consulting, Inc.
> 708 S. Battlefield Blvd., Chesapeake, VA 23322
> phone: (757) 546-3401
> e-mail: drrobison at openroadsconsulting.com
> web: http://openroadsconsulting.com
> blog: http://therobe.blogspot.com
> book: http://www.xulonpress.com/book_detail.php?id=2579
> !DSPAM:4033,4795347f311362458217002!
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
