[OpenLayers-Users] Problem wth ScaleBar
David R Robison
drrobison at openroadsconsulting.com
Mon Jan 28 15:40:11 EST 2008
It looks like I have the right code. I think the problem is with the
styleValue routine. I have had to modify the following code in the draw
function:
var vertDisp = 0;
for(var classIndex = 0; classIndex < classNames.length;
++classIndex) {
var cls = classNames[classIndex];
vertDisp = Math.max(
vertDisp,
this.styleValue(cls, 'top') + this.styleValue(cls, 'height')
if (vertDisp == 0) vertDisp = 30;
The vertDisp value was coming out to be zero. By adding the last line
and setting it to 30 it helped, but the bar still looks a bit off. I
load a number of style sheets and I think that there is an issue with
one that is causing the problem. I suspect the following code in styleValue:
if(typeof(sheet.cssRules) == 'undefined') {
if(typeof(sheet.rules) == 'undefined') {
// can't get rules, assume zero
break;
} else {
allRules = sheet.rules;
} else {
allRules = sheet.cssRules;
I am wondering if the "break;" should be a "continue;"? Any thoughts? David
Tim Schaub wrote:
> Hey-
> David R Robison wrote:
>> I was using the one in the tschaub sandbox. David
> If you take a look at the patch for the scale bar, you'll see there are
> some changes required to the default stylesheet.
> http://trac.openlayers.org/attachment/ticket/24/scalebar.patch
> In addition, you'll want to add your stylesheet with a link tag instead
> of relying on the default dynamically added stylesheet.
> <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
> Thanks for trying it out. Write back if you still have any trouble with it.
> Tim
>> Christopher Schmidt wrote:
>>> On Mon, Jan 21, 2008 at 06:43:27PM -0500, David R Robison wrote:
>>>> I am trying to get the OpenLayers.Control.ScaleBar working. I've added
>>>> it to my map according to the example html. However, when my map draws,
>>>> I get the units (in my case 'miles') but it displays at the bottom of
>>>> the map and I get no scale bar. Its as if the scale bar is below the map
>>>> and hidden. Any thoughts on how to get this to work correctly? Thanks, David
>>> Are you adding ScaleBar (which isn't in trunk) or Scale()? OpenLayers
>>> does not currently have a ScaleBar control.
>>> Regards,
>> David R Robison
>> Open Roads Consulting, Inc.
>> 708 S. Battlefield Blvd., Chesapeake, VA 23322
>> phone: (757) 546-3401
>> e-mail: drrobison at openroadsconsulting.com
>> web: http://openroadsconsulting.com
>> blog: http://therobe.blogspot.com
>> book: http://www.xulonpress.com/book_detail.php?id=2579
>> !DSPAM:4033,4795347f311362458217002!
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
David R Robison
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080128/e8b2aa4a/attachment.html
