[OpenLayers-Users] Displaying the whole world centered on Pacific
Pierre-Benoit Besse besse.pb at gmail.com
Fri Jul 4 10:21:36 EDT 2008
Thank you Paul, it works.
But I have an other problem now. I have a point shapefile containing
population density. I display each point as a square to cover the entire map
without holes.
To do it I had to set the singleTile property of the layer to "true" or I
had white lines on tiles borders (the squares are drawn only on the tile
containing the point).
But it doesn't work with a wrapDateLine to "true" too. It cuts the map at
long 180 (-180) and switches to one 'side' or the other, but it never
displays both side at once.
Is there anything I can do about it ?
P.S : I don't know if I made myself clear, if not please ask for details.
2008/7/3 Paul Spencer <pagameba at gmail.com>:
> Hi Faldor,
> you do need to use -180 -> 180, but I think you can get this to work using
> the wrapDateLine propery, see the wrapDateLine.html example and then set the
> center of your map to a geographic location in the pacific.
> Cheers
> PAul
> On 3-Jul-08, at 11:30 AM, Faldor wrote:
>> Hi all,
>> Is there a way to display a map of the whole world not centered on Europe
>> Until today I defined the "maxExtent" property of my "map" object with
>> (-180, -90, 180, 90).
>> I wish to display it centered on Pacific but I tried (0,..,360,..)
>> (0,..,0,..) etc... and it didn't work. For exemple with (0,..,360,..) it
>> displays from 0 to 180 but cuts the rest.
>> How can I solve this ?
>> I display data from a MapServer server, I tried to edit the EXTENT
>> property
>> in the mapserver's mapfile but it changed nothing.
>> Best Regards,
>> Faldor
>> View this message in context:
>> http://www.nabble.com/Displaying-the-whole-world-centered-on-Pacific-tp18260454p18260454.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080704/5f91a989/attachment.html
