[OpenLayers-Users] read Format.GeoRSS from http request
Fabio D'Ovidio
fabiodovidio at gmail.com
Mon Jul 14 04:12:09 EDT 2008
Hi!
If I try like this from localhost:8080:
function test3 () {
var urlObj = "http://localhost/georssFeed.php?list=2,3";
OpenLayers.Format.GeoRSS.prototype.xy = true;
var new1 = new OpenLayers.Layer.GML("GeoRSS", urlObj, {format:
OpenLayers.Format.GeoRSS});
map.addLayers([new1]);
I have no problem to display my features!
So I think the problem now is only related to the ProxyHost
Thanks!
bartvde at osgis.nl ha scritto:
> Fabio,
> leave out the new keyword before OpenLayers.Format.GeoRSS.
> Wrt proxy, please read:
> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#HowdoIsetupaProxyHost
> Best regards,
> Bart
>> Christopher Schmidt ha scritto:
>>> I didn't suggest using a Layer.GeoRSS. I suggested using a Layer.GML
>>> with a Format.GeoRSS.
>>> Regards,
>> Hi!
>> I'm trying as following:
>> function test3 () {
>> var urlObj = "http://127.0.0.1:80/myapp.php?";
>> var test = new OpenLayers.Layer.GML("GeoRSS", urlObj, {format:
>> new OpenLayers.Format.GeoRSS({'xy': true})});
>> map.addLayers([test]);
>> The errors are:
>> * Error in loading GML file on http://127.0.0.1:80/myapp.php?
>> * this.format is not a constructor
>> var gml = this.format ? new this.format(options) : new
>> OpenLayers.Format.GML(options);
>> in GML.js
>> About the first one i think the problem is related to
>> OpenLayers.ProxyHost. How can I set it using OpenLayers from
>> 127.0.0.1:8085?
>> Consider that var urlObj = "http://127.0.0.1:80/myapp.php?" is the
>> output of an xaction inside Pentaho BI application that runs on Jboss.
>> It works, there are no problems about it, but I need to use OL from
>> Jboss while myapp.php runs on 127.0.0.1:80.
>> Thanks again!
>> Ing. Fabio D'Ovidio
>> INOVA Open Solutions s.r.l.
>> Web : http://www.inovaos.it
>> Tel.: 081 197 57 600
>> mail: fabiodovidio at gmail.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Ing. Fabio D'Ovidio
