[OpenLayers-Users] Smooth transition between two Image layers
Jesper Larsen
jesper.webmail at gmail.com
Tue Jul 15 03:34:45 EDT 2008
Hi Kenneth and others,
Thank you for taking the time to elaborate on Christophers suggestion,
it was really helpful (I am new to OpenLayers so I haven't really got
an overview of the code). It seems to solve the problem. I will modify
my own version of the OpenLayers code as a first step. When I am more
confortable with the code and use larger parts of it I will try to
submit a patch (otherwise I will probably just break something else).
Regarding turning on "Smooth transition": My impression from the
documentation is that there are only two transition options (for
Layers), namely null and resize. Where is the option you mention
described?
Regards,
Jesper
2008/7/15 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>:
> As I understand Christopher's answer, this is not built into OpenLayers.
> So, you must modify the source code yourself to get this behavior.
> "Nothing you can do" then translates to, "There is no option you can switch
> on".
> You can start up by looking into Layer\Image.js and the function "setUrl"
> which calls Tile\Image.js "draw", which in turn invokses .\Tile.js "draw".
> You can see here that it calls "clear", which is implemented in
> Tile\Image.js.
> I suppose you can simply comment out line 188 in Tile\Image.js:
> clear: function() {
> if(this.imgDiv) {
> //this.hide(); --> Commented out
> if (OpenLayers.Tile.Image.useBlankTile) {
> this.imgDiv.src = OpenLayers.Util.getImagesLocation() +
> "blank.gif";
> I have not tested it, so i probably has some sideeffects.
> You may also want to turn on Smooth transition, as that prevents the
> original
> image from hiding before the new one is visible.
> And it is fairly annoying to maintain a modified version of OpenLayers, so
> if at all possible,
> you should consider adding this as a selectable option, and submitting the
> change as a patch.
> Another option is to replace the function at runtime, but that is bound to
> break when
> OpenLayers is updated.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Jesper Larsen skrev:
> Hi Christopher, realjax and others,
> As I understand your answer Christopher there is nothing I can do to
> avoid the blinking. Is that a correct understanding? In case that is
> not how I should understand your answer I have setup a minimal demo of
> the problem on:
> http://jlar.webfactional.com/static/
> When you press the switch button (with most of the browsers I have
> tested) the OpenLayers map blinks but the ordinary html img attribute
> does not. Any help on this issue is still very welcome.
> Regards,
> Jesper
> 2008/7/11 Christopher Schmidt <crschmidt at metacarta.com>:
> On Fri, Jul 11, 2008 at 12:37:05AM -0700, realjax wrote:
> Jesper-5 wrote:
> Is the solution to this to use Tween to create a smooth transition
> between to Layers? I tried it but I haven't been able to understand
> how to do it. I hope someone can help me out. What I tried is simply:
> OpenLayers.Tween is not likely going to suit your needs.
> I think you need to search for an external solution that has one layer fade
> out while the other fades in. You could (with a bit of hacking) prolly get
> this working in combination with a lightweight framework like Mootools for
> example.
> I don't think this will do what he wants. The proble is that OpenLayers
> intentionally hides images before they're loaded -- look at delayDisplay
> in OpenLayers.Util.createImage.
> In general, we have put no effort into changing this behavior.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
