[OpenLayers-Users] wfs stylemap example?
Arnd Wippermann arnd.wippermann at web.de
Thu Jul 31 16:44:51 EDT 2008
Instead of "select" try "crosshair".
I init my cursor for select with
OpenLayers.Feature.Vector.style['select']['cursor'] = 'crosshair';, but it
doesn't work. But when i select and then unselect a feature, then the cursor
will change, when I hover over the feature.
Perhaps it is bug. When I look in my application at the generated svg in
firebug, there is no attribute "cursor". But after a select the attribute is
added.
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: adube at mapgears.com [mailto:adube at mapgears.com]
Gesendet: Donnerstag, 31. Juli 2008 15:44
An: Christopher Schmidt
Cc: Arnd Wippermann; users at openlayers.org
Betreff: Re: [OpenLayers-Users] wfs stylemap example?
Christopher Schmidt wrote:
> Alternatively, set your strokeWidth to a larger number (I always use 3).
Wow !  Haven't though about that but it's a simple and clever solution
:)  Thanks.
> You can't change the color when hovering, but you can change the cursor:
> set OpenLaeyrs.Feature.Vector['default'].cursor = "select"; and it
> will change the cursor when it is over a feature.
I think it's more like :
OpenLayers.Feature.Vector.style['default'].cursor = "select";  but it's not
working.  The value "" of the cursor IS changed to "select", but that does
nothing when my mouse is over a feature.
In OpenLayers.Features, I have Vector and WFS.  I assumed that because my
layer is WFS I had to change my cursor there but it has no style.
Any ideas ?
> No real way to do that with the current code. Specifically, the reason
> is becasue the event is determined based on the browser saying "Here
> is the element that was under the mouse when the event triggered." But
> making the feature bigger will help.
I will try to think of something.
Alexandre Dubé
Mapgears
www.mapgears.com
