[OpenLayers-Users] FramedCloud with Layer.Text?
Erik Uzureau
euzuro at gmail.com
Thu May 1 11:55:45 EDT 2008
A ticket would be great!
Erik
On Thu, May 1, 2008 at 10:10 AM, jericks <JERICKS at co.pierce.wa.us> wrote:
> I ran into the exact same problem and came up with a small patch to
> OpeLayers.Layer.Text that adds popupClass as a property. When the
> OpenLayers.Feature object is created it's popupClass property is set. Very
> useful for people dependent on Text layers. I will attach the patch here,
> but I should probably open a ticket right?
> Thanks,
> Jared
> http://www.nabble.com/file/p16993296/text_popup_class_patch.patch
> Christopher Schmidt-4 wrote:
> > On Mon, Apr 21, 2008 at 10:39:56AM -0400, Bobby H. Braswell wrote:
> >> Hi-
> >> Is there an example of using the framed cloud popups with a text layer
> >> in 2.6? In general can we specify the popup type when constructing a
> >> text layer?
> > Generally, the answer is 'no, and why are you still using a Layer.Text?
> > Use a Layer.GML with a format: OpenLayers.Format.Text and a
> > selectFeature control instead.'
> > I understand that this is impractical for long running applications (we
> > maintain backwards API compatibility for a reason, after all).
> > Anyway, the following hacks will let you get something that I like a lot
> > better for text layers:
> > OpenLayers.Feature.prototype.popupClass =
> > OpenLayers.Popup.FramedCloud;
> > OpenLayers.Layer.Text.prototype.markerClick = function(evt) {
> > var sameMarkerClicked = (this == this.layer.selectedFeature);
> > if (this.popup) {
> > this.popup.toggle();
> > } else {
> > this.layer.map.addPopup(this.createPopup(true));
> > this.layer.selectedFeature = (!sameMarkerClicked) ? this :
> > null;
> > OpenLayers.Event.stop(evt);
> > Good Luck,
> > Christopher Schmidt
> > MetaCarta
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> View this message in context: http://www.nabble.com/FramedCloud-with-Layer.Text--tp16811991p16993296.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
