[OpenLayers-Users] Problem with projection of rasters...
Eric Lemoine eric.c2c at gmail.com
Sun May 4 08:04:59 EDT 2008
On Tue, Apr 29, 2008 at 2:27 PM, Clemiou <clems_mars at hotmail.com> wrote:
>  Hi all!
Hi Clemiou
>  I come back here because I always have the same problem.
>  So, I have a .ewc file which represent the France. This file is in Lambert II (French position, centered on France).
>  Currently, I display this map with WGS84 projection but naturally, my map is distorded because this projection is centered on the equator.
>  So, if I try to displaying my map with the Lambert II projection, I obtain the following figure:
>  http://www.forumsig.org/attachment.php?attachmentid=2286&stc=1&d=1208951661
Your link requires authentication.
>  As you can see, there is a malfunction=> the repetition of a part of each tile.
>  I tried to add projection and units options to my map but nothing change. I think that is a OL probleme because my map is correctly display with Mapserver and without OL.
I've used OpenLayers with Lambert II layers a couple times and haven't
experienced any problems. Please try isolating the problem and send
some html/JS code. I'll try to assist you...
Cheers,
Eric
