[OpenLayers-Users] Local File System Layer?
Eric Lemoine
eric.c2c at gmail.com
Sun May 4 08:14:40 EDT 2008
On Sun, May 4, 2008 at 3:55 AM, Kurt D. Bollacker <kurt at longnow.org> wrote:
> I've got an unusual use for OpenLayers. I'm trying to create an image
> browser for a very large image-- 648000 by 648000 pixels to be exact.
> This image will be the "rosetta disk" that we are creating. See
> http://www.rosettaproject.org to check out our project.
> My first attempt was to hack the app at:
> http://www.casa.ucl.ac.uk/software/googlemapimagecutter.asp
> I created a bunch of image tiles at various resolutions and then was
> able to Use the Google Maps API to create the browser I needed, EXCEPT
> that the local javascript calls google.com for support functions. So
> even though the HTML and javascript are local and the tiles are all
> local, I still need internet access to view the image.
> OpenLayers was suggested as a replacement. What I'd like to do is
> build an image viewer than can run totally locally without more than a
> web browser (no HTTP). I was hoping there'd be a
> OpenLayers.Layer.LocalFileSystem class that I could use directly. I
> can easily slice and dice my tiles to be any size and resolution, and
> I'm willing to bring in additional javascript libraries.
> So what should I do? Am I missing something obvious? Should I try to
> subclass OpenLayers.Layer to use the local file sytem? Any
> suggestions or pointers are greatly appreciated.
> Thanks..
> Kurt :-)
Hi
FireFox can read local files using the file protocol (file://), I'm
not sure about other browsers. So with FireFox and Layer.TileCache or
Layer.TMS you can probably meet your goal. FWIW, gdal has a utility
command to generate a directory woth TMS tiles. See
<http://www.isere.equipement.gouv.fr/article.php3?id_article=6>.
TileCache also has such a utility, namely tilecache_seed.py.
Hope this helps,
Eric
