[OpenLayers-Users] Changing map projections for WMS layers
Jon Blower
jdb at mail.nerc-essc.ac.uk
Tue May 6 06:47:34 EDT 2008
Hi Eric (and list),
Thanks for this. I now have a different problem, in that
map.zoomToMaxExtent() is not working as expected on my north polar
stereographic layer. I have registered an event handler for
map.changebaselayer that looks like this:
function baseLayerChanged(event)
// Change the parameters of the map based on the new base layer
map.setOptions({
projection: projCode,
maxExtent: map.baseLayer.maxExtent
map.zoomToMaxExtent();
The base layers are set up with different projections (one in
EPSG:4326, the other in EPSG:32661). Logging reveals that, when
switching to EPSG:32661, the maxExtent of the map is being set
correctly *but* the true extent of the map after the call to
zoomToMaxExtent() is not correct:
max extent of map: -10700000, -10700000, 14700000, 14700000
actual extent of map after call to zoomToMaxExtent: 1999640,
1999718.75, 2000360, 2000281.25
hence the map is only covering a very small portion of the true
maximum extent. Are there other parameters that I should be setting
on the base map? I am not setting resolution, minExtent or zoom
levels explicitly anywhere in my code.
The same thing happens if I call zoomToExtent() and pass in the
bounding box explicitly.
Thanks, Jon
On Sun, May 4, 2008 at 1:34 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> On Fri, May 2, 2008 at 5:14 PM, Jon Blower <jdb at mail.nerc-essc.ac.uk> wrote:
> > Hi all,
> > I am developing a WMS-based visualization site using OpenLayers and
> > I'd like to have the capability to change the projection of the map.
> > The map is created using EPSG:4326 but I'd like to be able to change
> > this dynamically to EPSG:32661 (north polar stereographic). (so that
> > I can display layers from NSIDC, amongst others:
> > http://nsidc.org/data/atlas/ogc_services.html).
> > I've tried changing the projection like this:
> > map.setOptions({
> > projection: "EPSG:32661",
> > maxExtent: new OpenLayers.Bounds(-10700000, -10700000, 14700000, 14700000)
> > but nothing seems to happen. The map doesn't change at all, even if I
> > zoom or pan. Images are still requested using EPSG:4326 and the
> > extent remains unchanged. (The base layer WMS can accept either
> > EPSG:4326 or EPSG:32661.)
> > All the layers on my map are WMS layers.
> > Do I need to change the projection of all the layers I'm viewing
> > individually?
> yes, I think so.
> > If so, what is the purpose of the projection of the map
> > object?
> If a layer is created without a projection specified, its projection
> is taken from what's specified in the map object.
> Eric
Dr Jon Blower Tel: +44 118 378 5213 (direct line)
Technical Director Tel: +44 118 378 8741 (ESSC)
Reading e-Science Centre Fax: +44 118 378 6413
ESSC Email: jdb at mail.nerc-essc.ac.uk
University of Reading
3 Earley Gate
Reading RG6 6AL, UK
