[OpenLayers-Users] OverviewMap: custom layer + custom projection
Martin Ouellet
geomartino at gmail.com
Fri May 2 14:30:15 EDT 2008
Hi all,
I would like to have a custom layer (different from the baselayer) and a
custom projection (same as the base layer of course) in my overviewmap:
I've tried this:
//baselayer based on tilecache
baseLayer = new OpenLayers.Layer.WMS ( "Carte de base",
http://osl1/tilecache/tilecache.py?",
http://osl2/tilecache/tilecache.py?",
http://osl3/tilecache/tilecache.py?",
http://osl4/tilecache/tilecache.py?"
{ layers : "siglight3",
map_projection:
"init=epsg:42105",
transparent: "true" },
{ isBaseLayer: true }
//WMS layer for the overview
var wms_ov = new OpenLayers.Layer.WMS ( "overview",
"http:/...",
{ layers : "muncp",
map_projection: "init=epsg:42105",
transparent: "true",
format: "gif"
{ isBaseLayer: false, singleTile: true
//options for the ov (from the ol wiki)
var ov_options = {layers: [wms_ov],
maxExtent: new OpenLayers.Bounds(30000, 75000, 1709360,
2120440),
projection:"EPSG:42105",
units: "m"
//adding the control
var overview = new OpenLayers.Control.OverviewMap( {mapOptions: ov_options}
map.addControl(overview);
With this configuration, I still have a popup message you tell me that the
projection of the ov must be equal to the one in the baselayer (Why?).
And, If a check the call made by openlayers for the ov, the SRS seem to be
4326 (why?) and the bounding box is in lat/lon (Why?).
http://mdrim00-000251/MapServer5/mapserv.exe?MAP=overview.map&LAYERS=direction_territoriale&MAP_PROJECTION=init%3Depsg%3A42105&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-180,-90,332,422&WIDTH=256&HEIGHT=256
any advice on this?
MartinO
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080502/c038f2b0/attachment.html
