[OpenLayers-Users] Beginner Virtual Earth Problems
Richard Marsden
richard at winwaed.com
Fri May 2 17:06:04 EDT 2008
I am currently using MapServer and OpenLayers for an online mapping
project to display a rain forest study area - unfortunately I'm a bit
of a beginner with both! I'm currently having problems using Virtual
Earth in OpenLayers: in particular switching between layers, and with VE
versions.
Virtual Earth isn't suitable for the main map because our study area is
only about 10ha of Costa Rican rain forest - ie. the detail just isn't
there. However, I am try to use Virtual Earth as an optional base map to
show the study area in context.
I've managed to get the OpenLayers Virtual Earth sample working with a
MapServer WMS hydrology overlay ('synthetic streams').
I'm currently trying to get it to work with an alternative "outline map".
Ie. there are two base layers that can be chosen with a pair of radio
buttons in the LayerSwitcher: 'Virtual Earth Base Layer', and
'Outline' (WMS delivered shape file)
An optional overlay is selected with a checkbox: 'Synthetic streams'
(also via WMS).
This is a work in progress so the colours could be improved, but my
results are here:
http://www.ecomapcostarica.com/map/map_beta.html
Virtual Earth imagery loads okay at first. Switching to the 'Outline'
works as well. However, when I switch back to Virtual Earth, it fails to
re-appear. Instead, Outline is replaced with a white fill.
What am I doing wrong? Or is this kind of behaviour not supported?
This is my Javascript:
<script src="http://dev.virtualearth.net/mapcontrol/v3/mapcontrol.js"></script>
<script src="./OpenLayers.js"></script>
<script type="text/javascript">
var lon = -84;
var lat = 10;
var zoom = 7;
var map;
var stream_layer, velayer, bound_layer, outline_layer;
function init(){
map = new OpenLayers.Map( 'map' );
velayer = new OpenLayers.Layer.VirtualEarth("Virtual Earth Base Layer",
{ minZoomLevel: 4, maxZoomLevel: 8, 'type': VEMapStyle.Aerial } );
map.addLayer(velayer);
outline_layer = new OpenLayers.Layer.MapServer( "Outline",
"http://www.ecomapcostarica.com/map/mapserv.cgi?map=/usr/home/winwaed/mapdata/cr_outline.map", {layers: 'outline'},
{gutter: 15});
map.addLayer(outline_layer);
stream_layer = new OpenLayers.Layer.MapServer( "Synthetic Streams",
"http://www.ecomapcostarica.com/map/mapserv.cgi?map=/usr/home/winwaed/mapdata/cr_stream.map", {layers: 'streams', transparent:'true'},
{gutter: 15});
map.addLayer(stream_layer);
map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
map.addControl( new OpenLayers.Control.LayerSwitcher() );
</script>
I've also tried changing the script to use v6.1 of the Virtual Earth
Control, ie.:
<script
src="http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.1"></script>
The results can be seen here:
http://www.ecomapcostarica.com/map/map_ve.html
The default "North America" map appears - not my selected area at all,
and none of the OpenLayers controls (zoom, layer selection, etc) appear.
Is v3 the latest version supported by OpenLayers? Are there any plans
to update this in the near future? I see that Microsoft are actively
retiring old versions of the Virtual Earth API.
Thanks in advance. OpenLayers and MapServer are both capable of some
pretty neat stuff - I have high hopes regarding the final result!
Richard Marsden
Wiwnaed Software Technology LLC
http://www.winwaed.com
http://www.mapping-tools.com
