[OpenLayers-Users] No imagery message tile like Google Maps
zenzero-2001
John.Westwood at port.ac.uk
Thu May 8 09:47:41 EDT 2008
I got it to work using the MapServer method, after I removed the "BACKGROUND"
command. However, because I have a large tilecache buffer the text does not
appear on every tile.
I would rather get it to work the other way, thus bypassing tilecache. But
to do this I need MapServer to generate an exception when a map is requested
at an unsupported scale.
Thanks for your suggestion.
Since you are hitting mapserver anyway to generate the error message,
you might as well have it generate the no data tile:
LAYER
NAME "nodata"
STATUS ON
TYPE ANNOTATION
TRANSFORM FALSE # feature is in pixel space, not geographic space
FEATURE
POINTS
128 128 # middle of a 256x256 tile draw
END
TEXT "No Data Available"
END
CLASS
MINSCALE 1
MAXSCALE 20000 # below this scale, there is no data
LABEL
FONT "arial" #defined in fonts.txt
TYPE TRUETYPE
SIZE 8
BUFFER 1
COLOR 0 0 0
BACKGROUND 255 255 255
FORCE TRUE
END
END
END
(adapted from http://mapserver.gis.umn.edu/docs/faq/copyright-layer)
Cheers
Paul
View this message in context: http://www.nabble.com/No-imagery-message-tile-like-Google-Maps-tp17105133p17125305.html
