[OpenLayers-Users] SOLVED: How do I create a kamap layer change
the tile, metatile sizes?
Paul Spencer
pagameba at gmail.com
Mon May 12 15:11:21 EDT 2008
Steve,
it looks like the docs specify two parameters, w and h, for the
constructor. Do you have a suggestion on how to provide more clarity?
Cheers
Paul
>> Hi all,
>> I need to create a KaMap tilecache layer in Openlayers, but it uses a
>> non-standard tile size 128x128 and 12x12 tiles per metatile. I was
>> reading through the code but it is not obvious to me how I can
>> override
>> the tile size. Thoughts?
> I added this to the options hash.
> tileSize: new OpenLayers.Size(64, 64)
> Also, the constructor definition for OpenLayers.Size in the API doc
> does
> not make it clear that this is the format, as opposed to what is
> implied
> by the w: h: notes that make it seem like you should feed it a hash,
> like:
> tileSize: new OpenLayers.Size({h: 64, w: 64})
> -Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
