[OpenLayers-Users] Is it possible to delete a point using
theModifyFeature control?
Arnd Wippermann
arnd.wippermann at web.de
Wed May 14 13:55:49 EDT 2008
Hi Andreas,
For this task (delete a whole feature) I have overwriten
OpenLayers.Control.ModifyFeature.prototype.handleKeypress.
With the key "k" i kill a feature (only FF).
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
OpenLayers.Control.ModifyFeature.prototype.handleKeypress = function(code) {
* Method: handleKeypress
* Called by the feature handler on keypress. This is used to delete
* vertices and point features. If the <deleteCode> property is
set,
* vertices and points will be deleted when a feature is selected
* for modification and the mouse is over a vertex.
* Parameters:
* {Integer} Key code corresponding to the keypress event.
//handleKeypress: function(code) {
// check for delete key
if(this.feature && OpenLayers.Util.indexOf(this.deleteCodes, code)
!= -1 && code != 107)
var vertex = this.dragControl.feature;
if(vertex &&
OpenLayers.Util.indexOf(this.vertices, vertex) != -1) {
// remove the vertex
vertex.geometry.parent.removeComponent(vertex.geometry);
this.layer.drawFeature(this.feature,
this.selectControl.selectStyle);
this.resetVertices();
this.onModification(this.feature);
else if(this.feature && OpenLayers.Util.indexOf(this.deleteCodes,
code) != -1 && code == 107)
var obj = this.feature;
var lyr = obj.layer;
this.unselectFeature(obj);
lyr.removeFeatures(obj);
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Andreas Hocevar
Gesendet: Mittwoch, 14. Mai 2008 08:15
An: OpenLayers Users
Betreff: [OpenLayers-Users] Is it possible to delete a point using
A question to all vector editing gurus:
Is it possible to make the ModifyFeature control delete a point by clicking
the Del button? I know that the Del button will delete vertices on
geometries, but what about points (only one vertex)?
Is there a simple workaround to delete the whole feature instead of a
vertex?
Thanks!
Andreas.
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
