[OpenLayers-Users] Is it possible to delete a point using theModifyFeature control?
Arnd Wippermann arnd.wippermann at web.de
Tue May 27 13:49:46 EDT 2008
Thanks Oscar,
That's right. I will update my code
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
  _____
Von: oscar.fonts.lists at gmail.com [mailto:oscar.fonts.lists at gmail.com]
Gesendet: Dienstag, 27. Mai 2008 08:53
An: Tim Schaub
Cc: Arnd Wippermann; users at openlayers.org
Betreff: Re: [OpenLayers-Users] Is it possible to delete a point using
2008/5/19 Tim Schaub <tschaub at opengeo.org>:
Arnd Wippermann wrote:
> I would appreciate, if the Control.ModifyFeature would enhanced to delete
> features.
This was originally the intent.  Chris suggested it would be too easy to
delete a feature accidentally when you were trying to hover over a
vertex.  Providing an option on the control seems like a sensible solution.
You could show a confirm dialog:
    handleKeypress: function(code) {
        // check for delete key
        if(this.feature && OpenLayers.Util.indexOf(this.deleteCodes, code)
!= -1) {
            var vertex = this.dragControl.feature;
            if(vertex && [..]) {
            } else { // Not over a vertex
                if(confirm("Do you want to delete the selected feature?")){
                    var f = this.feature;
                    this.unselectFeature(this);
                    this.layer.removeFeatures([f]);
Oscar.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080527/f0f4f681/attachment.html
