[OpenLayers-Users] popup hidden when goes on sides of viewport
Eric Lemoine eric.c2c at gmail.com
Fri May 16 18:03:56 EDT 2008
On Thu, May 15, 2008 at 2:21 PM, Kusum <kusum at infobase.in> wrote:
> Dear all
> I am caught in a very difficult situation. In my application the user marks
> a point on map and enters description to the point.
> Aslo uploads photos.
> a folder is made into which the uploaded photos go and then I fetch the
> string for all photos in folder.
> And then the description and photos are seen in popup.
> But if the user marks a second point and uploads other photos in other
> folder and then sees the popup.
> In second popup new photos are seen but then photos of first popup also
> change as now they start using the new fetched image string for new popup.
> Isn't there an id corresponding each FramedCloud popup that I can assign and
> later use to fetch photos corresponding to it.
If you pass null as the first arg to the popup constructor, OL will
create a popup id for you which you can refer to using popup.id. Would
that help?
Eric
