[OpenLayers-Users] rules depending on state
Tim Schaub
tschaub at opengeo.org
Mon May 19 15:39:04 EDT 2008
Pierre GIRAUD wrote:
> Yep,
> I already tried that and this works great.
> However, what if I want to set fillColor, strokeColor, fillOpacity and
> strokeOpacity at the same time ? This is really painful.
> And it seems like I need to provide a valid value for each possible
> value of state. Default style won't be applied to features that aren't
> in the switch cases.
> I would prefer something like :
> var lookup = {
> 'Insert': {
> fillColor: 'green',
> fillOpacity: 0.5
Yes, you're right, you need a different function for each symbolizer
property. However, it shouldn't be too painful.
function getValue(state, key) {
var value = lookup[state][key];
if(value == undefined) {
value = defaultSymbolizer[key];
return value;
var context = {
getFillColor: function(feature) {
return getValue(feature.state, "fillColor");
Wouldn't be too hard to allow the symbolizer to be a function. This
function would be called for each feature and would return a symbolizer.
In fact, this seems more intuitive than the style context stuff.
The style stuff can be made less twisted in OL3.
Tim
> Regards,
> Pierre
> On Tue, May 13, 2008 at 4:35 PM, Andreas Hocevar
> <andreas.hocevar at gmail.com> wrote:
>> Hey Pierre,
>> without having tried, something like the following should work:
>> var context = {
>> getStateColor: function(feature) {
>> switch(feature.state) {
>> case "Insert": return "green";
>> case "Update": return "yellow";
>> case "Delete": retrun "red";
>> var styleMap = new OpenLayers.StyleMap(new OpenLayers.Style({
>> strokeColor: "${getStateColor}"
>> }, {context: context}));
>> Regards,
>> Andreas.
>>> Hello OpenLayers styleMap gurus,
>>> I would like to have different symbolizers for the features depending
>>> on their state property.
>>> The addUniqueValueRules would look perfect for that but the context of
>>> the generated rules is feature.attributes. The state will not be
>>> evaluated because it's not one of those attributes.
>>> Has anyone a workaround to advice ?
>>> Regards,
>>> Pierre
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
> !DSPAM:4033,4829ade5124501137850744!
