[OpenLayers-Users] rules depending on state
Pierre GIRAUD
bluecarto at gmail.com
Tue May 20 03:08:31 EDT 2008
Hi Tim,
The last Andreas' proposal was put into a patch I commit yesterday.
http://trac.openlayers.org/changeset/7216
Eric reviewed this but you can still have a look and scream if you don't agree.
Regards,
Pierre
On Mon, May 19, 2008 at 9:39 PM, Tim Schaub <tschaub at opengeo.org> wrote:
> Pierre GIRAUD wrote:
>> Yep,
>> I already tried that and this works great.
>> However, what if I want to set fillColor, strokeColor, fillOpacity and
>> strokeOpacity at the same time ? This is really painful.
>> And it seems like I need to provide a valid value for each possible
>> value of state. Default style won't be applied to features that aren't
>> in the switch cases.
>> I would prefer something like :
>> var lookup = {
>> 'Insert': {
>> fillColor: 'green',
>> fillOpacity: 0.5
> Yes, you're right, you need a different function for each symbolizer
> property. However, it shouldn't be too painful.
> function getValue(state, key) {
> var value = lookup[state][key];
> if(value == undefined) {
> value = defaultSymbolizer[key];
> return value;
> var context = {
> getFillColor: function(feature) {
> return getValue(feature.state, "fillColor");
> Wouldn't be too hard to allow the symbolizer to be a function. This
> function would be called for each feature and would return a symbolizer.
> In fact, this seems more intuitive than the style context stuff.
> The style stuff can be made less twisted in OL3.
> Tim
>> Regards,
>> Pierre
>> On Tue, May 13, 2008 at 4:35 PM, Andreas Hocevar
>> <andreas.hocevar at gmail.com> wrote:
>>> Hey Pierre,
>>> without having tried, something like the following should work:
>>> var context = {
>>> getStateColor: function(feature) {
>>> switch(feature.state) {
>>> case "Insert": return "green";
>>> case "Update": return "yellow";
>>> case "Delete": retrun "red";
>>> var styleMap = new OpenLayers.StyleMap(new OpenLayers.Style({
>>> strokeColor: "${getStateColor}"
>>> }, {context: context}));
>>> Regards,
>>> Andreas.
>>>> Hello OpenLayers styleMap gurus,
>>>> I would like to have different symbolizers for the features depending
>>>> on their state property.
>>>> The addUniqueValueRules would look perfect for that but the context of
>>>> the generated rules is feature.attributes. The state will not be
>>>> evaluated because it's not one of those attributes.
>>>> Has anyone a workaround to advice ?
>>>> Regards,
>>>> Pierre
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
>> !DSPAM:4033,4829ade5124501137850744!
> Users mailing list
