[OpenLayers-Users] application/openlayers from GeoServer VS
OpenLayers JS code
Christopher Schmidt
crschmidt at metacarta.com
Fri May 23 11:09:03 EDT 2008
On Fri, May 23, 2008 at 07:51:53AM -0700, Brent Pedersen wrote:
> hi, your geoserver map is generating 1 big image, so there are no
> rendering issues at the edges of images. that's also why it's faster.
> your other map is generating tiles. so you're seeing the edge effects.
> you can get rid of hte edge effects, and improve the speed by using
> tilecache.
And you can change your custom map to behave like GeoServer by adding a
"'singleTile': true" option on the layer. (Not parameter!)
-- Chris
