[OpenLayers-Users] application/openlayers from GeoServer VS
OpenLayers JS code
springrider
springrider at hotmail.com
Fri May 23 11:55:43 EDT 2008
Thanks for your replies.
I have added the singleTile option for the layer and it works fine now for
the edges display. I will try to install TileCache next week to improve the
performance.
Have a good week end.
Sylvain
Christopher Schmidt-4 wrote:
> On Fri, May 23, 2008 at 07:51:53AM -0700, Brent Pedersen wrote:
>> hi, your geoserver map is generating 1 big image, so there are no
>> rendering issues at the edges of images. that's also why it's faster.
>> your other map is generating tiles. so you're seeing the edge effects.
>> you can get rid of hte edge effects, and improve the speed by using
>> tilecache.
> And you can change your custom map to behave like GeoServer by adding a
> "'singleTile': true" option on the layer. (Not parameter!)
> -- Chris
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/application-openlayers-from-GeoServer-VS-OpenLayers-JS-code-tp17426479p17428004.html
