[OpenLayers-Users] application/openlayers from GeoServer VS
OpenLayers JS code
springrider
springrider at hotmail.com
Tue May 27 14:54:55 EDT 2008
Good evening
Our server administrator has installed tileCache. I is not completely
optimized according to this document
(http://geoserver.org/display/GEOSDOC/TileCache+Tutorial) but it seems
effectively that the display is quicker.
Nevertheless, by zooming between Africa and South america, i obtain again
the edges discrepancies: http://193.43.36.238:8484/cache/tilecache-2.03/.
I tried to use the SingleTile option and it seems that it can not work with
TileCache.
Moreover, when i zoom in, at a certain level of zoom, i obtain a nice pink
tile ...
Do i need to set up some parameters in TileCache to solve this 2 issues?
Thanks for you help again
Sylvain
Christopher Schmidt-4 wrote:
> On Fri, May 23, 2008 at 07:51:53AM -0700, Brent Pedersen wrote:
>> hi, your geoserver map is generating 1 big image, so there are no
>> rendering issues at the edges of images. that's also why it's faster.
>> your other map is generating tiles. so you're seeing the edge effects.
>> you can get rid of hte edge effects, and improve the speed by using
>> tilecache.
> And you can change your custom map to behave like GeoServer by adding a
> "'singleTile': true" option on the layer. (Not parameter!)
> -- Chris
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/application-openlayers-from-GeoServer-VS-OpenLayers-JS-code-tp17426479p17497530.html
