[OpenLayers-Users] Projection Problem
George Mu'ammar
George at muammar.net
Sat Nov 1 09:53:49 EDT 2008
Can you describe when is it that you see all of it and when is it that
you see half. Do you do some operation (like pan/zoom) and then you
see only half ?
or is it that if you refresh the same page sometimes it draws all the
map and sometimes half ? in this case it could be a performance
problem of mapserver.
What exactly happens when you try to pan ? in what sense you are not
able to pan ?
Is the map online ? can we see ?
Sorry too many questions
George
Quoting Kusum <kusum at infobase.in>:
> I am using orthographic projection to generate globe layer
> Its showing globe but sometimes half of it or some part.
> Also I am not able to rotate or pan through the globe.
> In openlayers I am using var options =
> controls: [],
> restrictedExtent: extent,
> numZoomLevels: 10,
> maxResolution:0.49990340909090999,
> projection:"EPSG:9840"
> and my mapfile is as follows:-
> EXTENT -180 -90 180 90
> UNITS DD
> SIZE 550 450
> PROJECTION
> "proj=ortho"
> "ellps=WGS84"
> "lat_0=51.0000"
> "lon_0=0.0000"
> "x_0=0.00"
> "y_0=0.00"
> END
> #World_Background
> LAYER
> NAME "background1"
> STATUS DEFAULT
> PROJECTION
> "proj=latlong"
> END
> TYPE RASTER
> DATA "wsiearth.tif"
> TEMPLATE "ttt.html"
> END
> I am confused this is due to the extent I have set or projection definition
> set in mapfile.
> Please help as this is very urgent and I have a deadline to meet.
> Regards
> Kusum
> From: "Arnd Wippermann" <arnd.wippermann at web.de>
> Sent: Friday, October 31, 2008 11:01 PM
> To: "'Kusum'" <kusum at infobase.in>
> Cc: <users at openlayers.org>
> Subject: AW: [OpenLayers-Users] Projection Problem
>> You can use MapServer to reproject your georeferenced tiff and
>> OpenLayers.Layer.MapServer (or OpenLayers.Layer.WMS) to request it from
>> Mapserver.
>> OpenLayers can not reproject raster data as a desktop application as
>> arcgis
>> can do. But MapServer could do this part.
>> Arnd Wippermann
>> -----Ursprüngliche Nachricht-----
>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
>> Auftrag von Kusum
>> Gesendet: Freitag, 31. Oktober 2008 12:46
>> An: George Mu'ammar; users at openlayers.org
>> Betreff: Re: [OpenLayers-Users] Projection Problem
>> Actually I had a tiff image and it was geo referred and in arc gis I was
>> able to see it as globe by changing its projection and to see it in
>> openlayers I used OpenLayers.Layer.Image
>> Did I use the wrong option or Had I to use something different??
>> Pls reply
>> Regards
>> Kusum
>> From: "George Mu'ammar" <George at muammar.net>
>> Sent: Friday, October 31, 2008 5:10 PM
>> To: <users at openlayers.org>
>> Subject: Re: [OpenLayers-Users] Projection Problem
>>> Dear Kusum, do this test:
>>> Open your gif using any graphics application or browser. Does it look
>>> like the map you want to see ? You won't get anything more than that
>>> from using an Image layer.
>>> Regards
>>> George Mu'ammar
>>>> Dear All
>>>> I have a world image which I want to show at orthographic projection
>>>> so that it appears as a globe.
>>>> So I am using this image
>>>> var options =
>>>> numZoomLevels: 10,
>>>> layer = new OpenLayers.Layer.Image(
>>>> 'World Map',
>>>> 'http://localhost/maplab/app_atlas/images/wsiearth.GIF',
>>>> new
>>>> OpenLayers.Bounds(-180,-47.48309659090924,180,90),
>>>> new OpenLayers.Size(580, 320),
>>>> options);
>>>> But it is shown as a flat image and not as globe.
>>>> I am using Mapserver .
>>>> Is there any code change I have to make to get the image in globe form.
>>>> Pls suggest.I am completely messed up.
>>>> regards
>>>> Kusum
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> Users mailing list
