[OpenLayers-Users] setting WKT returned from postGIS in form
fieldto openlayers feature
Lehtonen, Mika
mika at digikartta.net
Sun Nov 2 15:11:43 EST 2008
Hi Robert,
I may be wrong, but doesn't proj4js.code have a libPath setting which
also defines where the defs can be found. So if you don't change it or
put your defs where they should be, they can't be found.
- mika -
Burgholzer,Robert kirjoitti:
> // I think the following projections should be set up
> automagically, but my installation does not seem to work without
> explicitly defining them here
> Proj4js.defs["EPSG:4326"] = "+proj=longlat +ellps=WGS84
> +datum=WGS84 +no_defs";
> Proj4js.defs["EPSG:900913"] = "+proj=merc +a=6378137
> +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
> +nadgrids=@null +no_defs";
