[OpenLayers-Users] setting WKT returned from postGIS in form fieldto openlayers feature
Mike Adair madair at dmsolutions.ca
Mon Nov 3 10:28:14 EST 2008
EPSG:4326 is included in Proj4js by default, EPSG:900913 isn't but I've
just updated Proj4js to include it now,
http://trac.osgeo.org/proj4js/ticket/20.  If you are including
Proj4js.defs elements, make sure they are put after Proj4js.js.  There
is a Proj4js.libPath property but it should be calculated automatically
and not even required if you include all required Proj4js.defs using the
script tag.
Mike
Lehtonen, Mika wrote:
> Hi Robert,
> I may be wrong, but doesn't proj4js.code have a libPath setting which
> also defines where the defs can be found. So if you don't change it or
> put your defs where they should be, they can't be found.
> - mika -
> Burgholzer,Robert kirjoitti:
>>           // I think the following projections should be set up
>> automagically, but my installation does not seem to work without
>> explicitly defining them here
>>           Proj4js.defs["EPSG:4326"] = "+proj=longlat +ellps=WGS84
>> +datum=WGS84 +no_defs";
>>           Proj4js.defs["EPSG:900913"] = "+proj=merc +a=6378137
>> +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
>> +nadgrids=@null +no_defs";
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
