[OpenLayers-Users] Cluster strategy and Google layer
mippon
smarty at programmer.net
Thu Nov 6 12:07:13 EST 2008
I am trying to get cluster strategy to work with google layers but it just
shows up in the middle of the map at wrong coordinates. Only one point shows
up. I cannot seem to figure out what I am doing wrong.
My script is as follows.
<script type="text/javascript">
var zoom = 5;
var map, layer;
function init(){
var options = {
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
units: "m",
maxResolution: 156543.0339,
maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
20037508.34, 20037508.34)
map = new OpenLayers.Map('map', options);
var mapnik = new OpenLayers.Layer.TMS(
"OpenStreetMap (Mapnik)",
"http://tile.openstreetmap.org/",
type: 'png', getURL: osm_getTileURL,
displayOutsideMaxExtent: true,
attribution: ' http://www.openstreetmap.org/
OpenStreetMap '
map.addLayer(mapnik);
map.addLayer(new
OpenLayers.Layer.Google("Google",{sphericalMercator:true}));
var style = new OpenLayers.Style({
pointRadius: "${radius}",
fillColor: "#ffcc66",
fillOpacity: 0.8,
strokeColor: "#cc6633",
strokeWidth: 2,
strokeOpacity: 0.8
context: {
radius: function(feature) {
return Math.min(feature.attributes.count, 7) +
3;
map.addLayer(new OpenLayers.Layer.Vector("GML", {
strategies: [
new OpenLayers.Strategy.Fixed(),
new OpenLayers.Strategy.Cluster()
projection: map.displayProjection,
protocol: new OpenLayers.Protocol.HTTP({
url: "gml/owls.xml",
format: new OpenLayers.Format.GML()
styleMap: new OpenLayers.StyleMap({
"default": style,
"select": {
fillColor: "#8aeeef",
strokeColor: "#32a8a9"
map.zoomToExtent(new
OpenLayers.Bounds(68.774414,11.381836,123.662109,34.628906).transform(map.displayProjection,
map.projection));
map.addControl(new OpenLayers.Control.LayerSwitcher());
function osm_getTileURL(bounds) {
var res = this.map.getResolution();
var x = Math.round((bounds.left - this.maxExtent.left) / (res *
this.tileSize.w));
var y = Math.round((this.maxExtent.top - bounds.top) / (res *
this.tileSize.h));
var z = this.map.getZoom();
var limit = Math.pow(2, z);
if (y < 0 || y >= limit) {
return OpenLayers.Util.getImagesLocation() + "404.png";
} else {
x = ((x % limit) + limit) % limit;
return this.url + z + "/" + x + "/" + y + "." + this.type;
</script>
View this message in context: http://www.nabble.com/Cluster-strategy-and-Google-layer-tp20365309p20365309.html
