[OpenLayers-Users] Freeform drawing
Eric Lemoine eric.c2c at gmail.com
Fri Nov 7 01:01:19 EST 2008
Hi. We already have that, this is the freehand mode of the path and
polygon handlers. By default freehand is false but can be activated by
pressing SHIFT while drawing. If you want freehand always active set
freehand to true in the handler options, and set freehandToggle to
null if you don't want the user to be able to activate non-freehand
key by pressing a modifier key. Cheers, Eric
2008/11/7, Kumar Mettu <mksreddy at yahoo.com>:
> Hi,
>   I am looking for adding a freeform pencil for user to draw over openlayers
> based map. Has anyone done this before?
> Thanks,
> Kumar.
