[OpenLayers-Users] Freeform drawing
Kumar Mettu mksreddy at yahoo.com
Fri Nov 7 13:41:39 EST 2008
Eric,
  Thanks. That helps.
   Is it possible to show a Image instead of circle on where the draw point is?
Thanks,
Kumar.
--- On Thu, 11/6/08, Eric Lemoine <eric.c2c at gmail.com> wrote:
Subject: Re: [OpenLayers-Users] Freeform drawing
To: mksreddy at yahoo.com, users at openlayers.org
Date: Thursday, November 6, 2008, 10:01 PM
Hi. We already have that, this is the freehand mode of the path and
polygon handlers. By default freehand is false but can be activated by
pressing SHIFT while drawing. If you want freehand always active set
freehand to true in the handler options, and set freehandToggle to
null if you don't want the user to be able to activate non-freehand
key by pressing a modifier key. Cheers, Eric
2008/11/7, Kumar Mettu <mksreddy at yahoo.com>:
> Hi,
>   I am looking for adding a freeform pencil for user to draw over
openlayers
> based map. Has anyone done this before?
> Thanks,
> Kumar.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081107/e543f9a4/attachment.html
