[OpenLayers-Users] Pass parameters to mapfile
Arnd Wippermann
arnd.wippermann at web.de
Sat Nov 8 16:21:27 EST 2008
If you have declared the variable user_id before mergeNewParams, it should
also work.
Because it is a Mapserver question, try and manipulate the request in the
browser and see what MapServer returns. If you get the response, you want,
then it is possible to get it also with OpenLayers.
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von S.Reena
Gesendet: Samstag, 8. November 2008 14:05
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Pass parameters to mapfile
One issue remains still ..
"http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www/html/customisation/map
file/customNR.map&userid=2"
is working ok with
DATA "the_geom from ( select * from customised_poly AS f where f.subcat_id
IN (select subcat_id from subcat_info where maincat_id =0) AND
user_id='%userid%' )AS foo1 USING UNIQUE gid"
but is I want to pass a dynamic value( a variable user_id) instead of a
number ( in this case 2) then its not happening .
I am still trying with wms[5].mergeNewParams({userid:user_id}) but its not
working yet
Thanks,
Reena.
Arnd Wippermann wrote:
> You can try to add the param to the url
> on/map
> file/customNR.map&userid=anID"
> and in the mapfile try user_id='%userid%'. In special cases it is
> possible per cgi-parameter manipulate the mapfile. I don't no if this
> case is one of them.
> Try the mapserver-list, because it is not an OpenLayers issue.
> To retrieve more than one layer with OpenLayers WMS you use
> {'layers' : 'NR_point,NR_polygon', 'transparent' : true, ... }, ...
> a comma-separatet list as christopher mentioned.
> Arnd Wippermann
> [mailto:users-bounces at openlayers.org] Im Auftrag von S.Reena
> Gesendet: Freitag, 7. November 2008 10:39
> Betreff: [OpenLayers-Users] Pass parameters to mapfile
> I am using the following data in my mapfile
> DATA "the_geom from ( select * from customised_point AS f where
> user_id='userid' AND f.subcat_id IN (select subcat_id from subcat_info
> where maincat_id =0))AS foo USING UNIQUE gid"
> I want the userid ( used in the above query) to be passed to map file
> at the time of layer creation something like this....
> wms[5] = new OpenLayers.Layer.WMS.Untiled(
> "Customization","http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www/
> html/c
> ustomisation/mapfile/customNR.map"
> + userid ,{'layers': "NR_point",'transparent':"true"},{'layers':
> "NR_polygon",'transparent':"true"},{'isBaseLayer':false} );
> How to do that?
> Thanks in advance :)
> Cheers,
> Reena.
> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20377405.h
> tml Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20395897.html
Users mailing list
