[OpenLayers-Users] Is the initial Map Image cached?
carls
carlshe at 163.com
Sun Nov 9 00:54:57 EST 2008
I found the solution.
Just call Layer.redraw(true).
Originally, I did call to redraw but without force parameter, so the map
can't be updated.
carls wrote:
> I need the baselayer/overlayer content can be changed dynamically.
> For example, the baselayer maybe refer a dynamic MapGuide Layer. Now I
> have changed the filter of a mapguide layer successfully and the map
> content can vary according to new settings as well. But if I scale the map
> to its initial bounds, the map content is shown exactly as same as its
> initial content. If I zoom the map to different scale, the map can reflect
> the dynamic result.
> Is the initial Map Image cached? If so, whether is it possible to add a
> switcher for the cache?
> Thanks?
Regards, Carl SHE
View this message in context: http://n2.nabble.com/Is-the-initial-Map-Image-cached--tp1472470p1475961.html
