[OpenLayers-Users] Pass parameters to mapfile
Tiemens, Gerben Gerben.Tiemens at grontmij.nl
Mon Nov 10 03:48:03 EST 2008
Your mapserver url can be extended with this paramter.. Try:
   "http://yourserv/mapserv?userid=" + customuserid + "&"
Greets
Gerben
-----Oorspronkelijk bericht-----
Van: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Namens S.Reena
Verzonden: Monday, November 10, 2008 9:18 AM
Aan: users at openlayers.org
Onderwerp: Re: [OpenLayers-Users] Pass parameters to mapfile
I tried as :
var quakes = new OpenLayers.Layer.WMS( "custom", "http://gis.rtbi-iitm.in/cgi-bin/mapserv?",
{map:'/var/www/html/customisation/mapfile/tnroad.map',transparent:true},{isBaseLayer:false});
 map.addLayer(quakes);
 quakes.mergeNewParams({layers:'tnroad',userid:'2'});
But mergeNewParams is not taking any value other than defaults for map (like in this case userid ). So %userid% is not replaced  in
  DATA "the_geom from ( select * from customised_poly AS f where f.subcat_id IN (select subcat_id from subcat_info where maincat_id =0) AND user_id=%userid% )AS foo1 USING UNIQUE gid"
Thanks,
Reena.
Arnd Wippermann wrote:
> Hi,
> If you have declared the variable user_id before mergeNewParams, it
> should also work.
> Because it is a Mapserver question, try and manipulate the request in
> the browser and see what MapServer returns. If you get the response,
> you want, then it is possible to get it also with OpenLayers.
> Arnd Wippermann
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org
> [mailto:users-bounces at openlayers.org] Im Auftrag von S.Reena
> Gesendet: Samstag, 8. November 2008 14:05
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Pass parameters to mapfile
> Hi,
> One issue remains still ..
> "http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www/html/customisati
> on/map
> file/customNR.map&userid=2"
> is working ok with
> AND user_id='%userid%' )AS foo1 USING UNIQUE gid"
> but is I want to pass a dynamic value( a variable user_id) instead of
> a number ( in this case 2) then its not happening .
> I am still trying with wms[5].mergeNewParams({userid:user_id}) but its
> not working yet
> Thanks,
> Reena.
>> You can try to add the param to the url
>> i
>> on/map
>> file/customNR.map&userid=anID"
>> and in the mapfile try user_id='%userid%'. In special cases it is
>> possible per cgi-parameter manipulate the mapfile. I don't no if this
>> case is one of them.
>> Try the mapserver-list, because it is not an OpenLayers issue.
>> To retrieve more than one layer with OpenLayers WMS you use
>> {'layers' : 'NR_point,NR_polygon', 'transparent' : true, ... }, ...
>> a comma-separatet list as christopher mentioned.
>> Arnd Wippermann
>> Gesendet: Freitag, 7. November 2008 10:39
>> Betreff: [OpenLayers-Users] Pass parameters to mapfile
>> I am using the following data in my mapfile
>>  DATA "the_geom from ( select * from customised_point AS f where
>> user_id='userid' AND f.subcat_id IN (select subcat_id from
>> subcat_info where maincat_id =0))AS foo USING UNIQUE gid"
>> I want the userid ( used in the above query) to be passed to map file
>> at the time of layer creation something like this....
>> wms[5] = new OpenLayers.Layer.WMS.Untiled(
>> "Customization","http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www
>> html/c
>> ustomisation/mapfile/customNR.map"
>> + userid  ,{'layers': "NR_point",'transparent':"true"},{'layers':
>> "NR_polygon",'transparent':"true"},{'isBaseLayer':false} );
>> How to do that?
>> Thanks in advance :)
>> Cheers,
>> Reena.
>> View this message in context:
>> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20377405.
>> h tml Sent from the OpenLayers Users mailing list archive at
>> Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20395897.h
> tml Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20415933.html
Users mailing list
<< Please read our E-mail Disclaimer at the Grontmij Corporate website >>
