[OpenLayers-Users] BBOX Update Bug
Tim Schaub tschaub at opengeo.org
Fri Nov 14 17:47:58 EST 2008
Hey-
GordonHo wrote:
> hi,
> i think the bbox has a small bug in the update handler.
> if an update is issued, and the retrieved data set is empty, the previous
> loaded data set is beeing displayed again after a zoom change.
> if the returned dataset is not empty, everything works fine.
At a glance, it looks to me like the merge callback should always get
called (this is the responsibility of your protocol).  If merge is
called, layer.destroyFeatures gets called (yes, this is a blunt merge).
So, I'm guessing something is going wrong in the protocol.  Could be a
parsing error.  If you are seeing any errors or have any more detail,
please open a ticket and attach anything relevant that helps reproduce
the problem (relevant detail would include at least the format and
protocol that you are using and ideally an example).
Thanks,
Tim
> with best regards and alot thanks for this framework, gordon
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
